Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-14-2007, 05:53 PM
BeerFizz is on a distinguished road
finding center of a hole
I have an edge finder with a conical end, which I guess may be used for finding the center of a hole.
In the Mach 3 offsets window, there is an area for using an edge finder to set the offsets.
I have played around with this and haven't got it to work just right.
I would like to be able to use this to find the exact center of a hole and then set this as X0, Y0.
Could someone please give me a step by step on how to do this.
Thanks.
Old 06-14-2007, 07:17 PM
Eurisko is on a distinguished road
It's much easier to find the center of a hole using a dial test indicator.
A spring action contact point easily adjusts to any angle. A needle on the graduated dial indicates how far the contact point moves.
Mount the indicator in the spindle, locate the contact point against the hole wall, and position the X&Y axes until the needle shows no movement (while rotating the spindle by hand).
You are now perfectly centered in the bore.
need help finding a cnc lathe joey1117 General Metal Working Machines 2 02-07-2007 04:02 PM
Finding the center Tazzer General Metalwork Discussion 6 08-05-2006 12:18 PM
Drilling a hole in the center of a bolt / newby question stickben Mechanical Calculations/Engineering Design 1 04-30-2006 11:07 AM
Help with finding DWG converter Enos Shenk G-Code Programing 3 12-19-2005 06:56 PM
Need help in finding brtlatjgt General CNC (Mill and Lathe) Control Software (NC) 1 06-03-2005 11:31 AM
