Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-14-2007, 05:17 PM
hindocarina is on a distinguished road
Keyboard shortcuts for jog commands?
I'd like to be able to set Z0 without touching the mouse. This way one hand could hold the feeler strip while the other hand cycles through the jog commands:
1. the tab key would open the jog window.
2. another key would set the jog mode to step.
3. another key would set the cycle jog step increment.
Is there a way to do this?
Thanks,
Charlie
Old 06-14-2007, 06:19 PM
9lrac9 is on a distinguished road
Hey... Charlie you answered it your self, Now that you found tab key. set your key board in front of you as I do, and set it on 1.00 or .100 .010 .001 and hit your page down or page up if you went Z- too much, I hit the key with my left hand and I'am l sliding the block at what ever height you want to set the Z at with my right hand. SIMPLE STUFF. Charlie what are you making...
9lrac9
Old 06-14-2007, 06:28 PM
Charlie... That's the safe way.
9lrac9
Old 06-14-2007, 06:56 PM
ger21's Avatar
http://www.artsoftcontrols.com/MachC...andard_Hotkeys
Old 06-14-2007, 08:57 PM
Smile I Know...
Just trying to keep it simple. After learning the 30000000000000000000000000...
hot keys in MC9. In Mach 3 I try to not go nuts... Thank you ger21
Old 06-14-2007, 08:59 PM
And yes I have downloaded all 154 pages of Mach 3
9lrac9
Old 06-14-2007, 09:29 PM
Thanks for the responses.
9Irac9, I'm making wooden ocarinas. Now you know as much as you did before...right? It's a type of musical instrument. If you're curious, you can see some of them on the following page from my website:
http://hindocarina.com/sweet_potato.htm
Charlie
G2 and G3 Commands Bohemund G-Code Programing 19 05-28-2007 09:12 AM
Difference between BL and SV commands? Shizzlemah Fadal 3 03-23-2007 08:33 AM
VCarve Pro Shortcuts dighsx Vectric 0 08-01-2006 04:20 PM
Thread commands on 6T control Ricardo Guedes Fanuc 2 02-03-2006 12:21 AM
EMC & the G28/G30 Home commands Javelin276 LinuxCNC (formerly EMC2) 1 07-18-2005 03:13 PM
