Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-13-2007, 09:47 PM
twistedfuse is on a distinguished road
Steppers Only Turn 1 way
Hello Everyone,
i am in the process of building a cnc machien and have gotten my all my electronics stuff up and running. My problem is that i came across a problem when i was stepping the motors and am not sure if its my hardware(HOBBYCNC board) or the software.
The problme is that One of my axis, my Y Axis, is only turning in one direction reguardless of whether i press the Y++ or Y-- hotkeys. I was wondering if anyone knew if there was a setting i could change to fix this or at least point me in the right directon. Im am very doubtful the driver chip is blown as it is spinning at the request of the buttons for both directions and the fact everything was done on antistatic mats and extreme care and all warnings were put in action like no removal of steppers till i could see 0v across the terminals. But it could have happend before i got it im not sure.
ANyway any help would be greatfully appreciated.
Daniel
Old 06-14-2007, 11:11 PM
gdb gdb is offline
gdb is on a distinguished road
Daniel
Try switching your step & direction numbers on the Y axis on the motor output page.
Worked for Me.
Glen
Old 06-17-2007, 03:13 AM
Fixed It
Hey everyone,
good news is that i finally fixed it. Somehow before i used the board it has either slipped into the protection mode or when i first switched it on it did it. It was as simple as switching the power ON-OFF-ON-OFF the letting it settle for a minute or two. Then its as good as new. If anyone has any weird errors with a drive of theirs on a Hobby CNC board i suggest that you might try it(ALthough most of you are probably quicker than me and tried it first). Its aways right there in front of you tesing you, and the last thing you try before losing your mind.
Daniel
(Not so frustraited now)
mill/turn on a cin turn Robert Timby General Metal Working Machines 4 01-31-2007 10:33 PM
Which to Turn on First or Not Mr.Chips General Electronics Discussion 10 01-31-2007 08:02 PM
Cin Turn turn/mill Robert Timby General CNC (Mill and Lathe) Control Software (NC) 0 01-24-2007 07:12 PM
how do i turn this? ramjack Mini Lathe 22 08-13-2006 09:46 PM
Cant get steppers to turn bigvinney General CNC (Mill and Lathe) Control Software (NC) 10 04-24-2006 08:22 AM
