Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-02-2007, 09:50 AM
cyclestart is on a distinguished road
line renumbering howto?
What's the easy way to renumber lines of code, set line increments, etc with Mach3? Currently I'm using Notepad which frankly bites, or else I don't know how to use it properly. This issue came up when running the roadrunner.tap sample code. Everything stopped part way through. Suspect the demo code limit was reached.
signed
A linux user in foreign territory
Old 06-02-2007, 10:01 AM
ger21's Avatar
Probably the limit. Mach3 will just stop at about 1000 lines of code.
You could load it into Excel as a space delimited file, and quickly add line numbers in there. Insert a column, enter 1 in the A1 cell, and drag down.
Old 06-02-2007, 11:00 AM
Excel, will check to see if I have that. Found NCPlot which does a very nice job of renumbering plus has some other useful features.
Yep, roadrunner is in the 4000 line range. Explains the stoppage pretty clearly.
Old 06-14-2007, 04:57 PM
hindocarina is on a distinguished road
Here's a great program:
http://www.editcnc.com/
Howto control Vexta UDX5114 via computer?? happytriger2000 Stepper Motors and Drives 22 04-19-2008 05:13 AM
Software to renumbering G-code files anorec Visual Basic 0 02-01-2007 12:33 PM
Howto: Set plane on angle. Deviant Solidworks 2 04-28-2005 12:06 PM
HOWTO: Create text in Radius Gujustud BobCad-Cam 1 03-22-2005 10:04 AM
Howto find input amps, from output amps on transformer? sendkeys General Electronics Discussion 7 07-14-2004 07:13 PM
