Hi, I just got the cnc of my mini mill completed. When I create a simple g-code file and run it, it flies around at full speed, ignoring the 'F' codes. Can anyone see what is wrong? Thanks.
| What does the feedrate DRO display while it's running?
| max speed, which is 50 IPM well, that is the combined feed rate... I'm at work at the moment so I can't just look, but I think it says what the actual 'F' is supposed to be. I can reduce it by some percentage by pulling down on the slider. |
Might need to adjust the length in "X", I'm not sure the size of your machines working area. ![]()
| You might also need the F2 to have a decimal point (F2.) My Fadal automatically configers to 3 decimal places if I don't add one myself. If I input F2 it automatically changes it to F.002
| Switcher, this is the code I used:
FRO: 2 Units/Min: 50 and it whipped 3 inches to the right and the back to zero. any ideas? |
#10
| What verson of MACH are you running? BAck in 1.84.something there were some problems with the modal triggers in MACH. Try this. MAke ALL of your moves using G01. No G00 commands. Put in one F command at the start. |
| OK goin in... full speed! | boosted | DIY-CNC Router Table Machines | 12 | 01-21-2007 03:41 PM |
| memory full | ad1z | Haas Mills | 5 | 11-16-2006 12:59 PM |
| BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? | peter.blais | Bridgeport and Hardinge Mills | 9 | 08-08-2006 03:29 AM |
| Deskproto 4 Full pricing? | saturnnights | General CAM Discussion | 1 | 03-08-2006 12:15 PM |
| CAM software for full 3D on a budget | Cliff_J | DIY-CNC Router Table Machines | 2 | 06-06-2004 03:36 PM |
