Hi, I have built a 3 axis routing system and trying to get Mach3 to run the steppers. Well the electronics part is also custom made. I am using a controller AT89S52 (8051 architecture) with 11.0592 Mhz crystal giving the ref frequency. The microcontroller is linke to a driver circuit built around a Sanyo chip (STK6713BMK4). The ckt is in good shape and the code for the Controller very simply done in Assembly. The problem is I configured Mach3 once .( Ports n Pins, Motor Tuning, Active Highs n Lows) once and tried it out . The system worked fine. I left in running condition overnight and the next day when i tried running it again.... the motors wont move at alll. There locked into position as soon as I power up and hit reset, but wont rotate. An electronics guy said that the Kernel frequency (25KHz) is a bit too high for the controller i am using..... Anybody with ideas or suggestions.. pls Help |
I don't think that's your problem. 25Khz is the maximum Mach3 is capable of. It only sends steps as fast as you tell it to.
| just a shot in the dark but you could try adjusting the step pulse under motor tuning and setup, if it is set to 0 change it to 5 or something, I had the same problem when I built my CNC and that fixed it. Also look at the settings of the ESTOP override under ports and pins setup, I had a problem with that too. Also had to put in a PCI adapter because the standard motherboard ports would not output enough power to the controller. Hope this helps and good luck. |
| Tuning motors in Mach3 | tybrenis | Mach Software (ArtSoft software) | 4 | 05-07-2007 01:59 PM |
| Stepper motors are still going at the incorrect speed. Need help with Mach3 | Apples | Mach Software (ArtSoft software) | 5 | 12-23-2005 05:29 PM |
| Manual turning of stepper motors | Pat | Stepper Motors and Drives | 1 | 08-08-2005 03:04 PM |
| It's getting there....motors are turning | johnt | CNC Plasma and Waterjet Machines | 1 | 03-27-2005 05:34 PM |
