Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 05-20-2007, 04:40 PM
bigz1's Avatar
bigz1 is on a distinguished road
mm on startup?
I have used Imperial ACME rod for my machine and used inches to set up in motor turning. How can I get mach3 to default to mm on the DROs when starting up rather than typing G21?
Also for squaring slaved motors x and a, is it standard practice to use the Homing offsets?
Old 05-20-2007, 05:38 PM
ger21's Avatar
Just set up the machine in mm. You can use two different configurations, one for inches and one for mm's.
Or, try putting G21 in the initialization string in Config>General Config
Old 05-20-2007, 05:44 PM
bigz1's Avatar
Thanks Gerry. Put it in string.
Startup Problem StormWerkz Fadal 14 03-06-2007 09:57 PM
V2XT Software Startup cncnavy Bridgeport and Hardinge Mills 8 02-17-2007 04:31 PM
oi-mc startup screen jamesweed Fanuc 2 02-09-2007 10:58 AM
Hurco BMC 20 startup problem tirebiter Machine Problems, Solutions , Wireless DNC, serial port 3 11-08-2006 04:50 PM
Need some startup advices... b_cybe DIY-CNC Router Table Machines 15 03-16-2006 04:18 PM
