I am generating 2D drawings using autoCad 2004, and saving the file as '.DXF'. Using Mach2Mill, I import the DXF drawing and generate the Gcode. The display (in Mach2) shows the drawn item correctly if it is a square, or a circle. The milled item (square or circle) is correct. If I draw an object such as a semi-circle with a straight line joining the ends of the semi-cicle, the graphic shown in Mach2 is incorrect and the milled shape is completely wrong. Within autoCAd 2004, there are 3 versions of DXF file that the drawing can be saved as, and I have tried all 3 with the same result. Thanks for any help. |
| Post the problem .dxf
. I also am trying to figure out Mach 2 and was going along fine until I punched something inadvertently now everything is in french and I cannot find a way to get the screen back to english . Any help appreciated ... mjh |
| Try View>Load screens and choose 1024.set when the file dialog opens. If the menu's are in French, View is the 4th menu from the left and Loas=d Screens is the first menu item.
| Importing dwg.files | wsteve | Rhino 3D | 2 | 05-09-2007 02:51 AM |
| About Importing Files | Gorillakilla | Mach Software (ArtSoft software) | 7 | 04-11-2006 04:37 PM |
| Importing files to turbocnc | mikburts | TurboCNC | 2 | 07-17-2005 06:35 PM |
| importing 3d iges files | jallen | BobCad-Cam | 0 | 07-07-2005 08:35 AM |
| importing files to machine | fastolds | GibbsCAM | 2 | 06-23-2005 07:48 AM |
