Is BobCad putting out code for circular cuts with absolute center coordinates instead of the incremental that you have setup in Mach3?
Gday to all,
I have a small problem when I generate code with bobcad 21 and then put the code into Mach 3 I get a perfect circle which should not be there. I have attached the code it is only the letter M which I am pocketing. I seem to get this more than I want to on all different job types. In state Distance Mode is Absolute and IJ mode is INC.
Try changing the IJ mode.
I have just noticed, for some reason there is an I and J code without any X or y Values.
I have found if I delete this part of code the program runs fine.
Any Ideas?
Hi Gerry, I have the same problem, how do you change the IJ mode?
Cheers
General Config screen
