Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 04-18-2007, 11:27 AM
alexccmeister is on a distinguished road
Mach2 and mach3 have different results.
Hi All,
Just want to ask if anyone of you came across this problem. I have been testing my stepper motors with mach2 and thought it worked fine until I downloaded mach3. My motors seems to run more realistically with Mach3 than it is with Mach2.
One example, when I run the g code to drill holes in a circular pattern, the z axis seems to run faster when using mach3 and in mach 2, the same z axis turns in steps and it is really slow. Is this due to a setting problem? I thought running both mach2 and mach3 should yield the same result. Apparently not. Anyone can help? I am using demo version for both. Thanks in advance.
Alex
Old 04-18-2007, 11:41 AM
turmite is on a distinguished road
Hi Alex,
While I don't have a lot of experience with Mach3 I have run Mach2 for 3.5 years now and have been very satisfied. I have Mach3 loaded on my machine and use it for digitizing and I do know that the tuning is much different for 3 than it was for 2. If 3 is running much better than 2 I would simply suggest you stay with 3.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 04-18-2007, 12:32 PM
ger21's Avatar
I'd expect Mach3 to run a bit better, as it's a much improved version of Mach2. If all the settings are the same, you should get accurate results with either one though. Are you're CV settings the same?
Old 04-18-2007, 09:27 PM
Thanks Mike.
Gerry, What is a CV? Sorry 'warning' Newbie here. Yes, I am thinking the result should be the same for both. But when I run with mach3, the turning of the z axis motor is more representative of the leadscrew turning a proper distance. But with mach2, the z axis motor was like stepping twice every second. You wouldn't see any reasonable linear movement from this at all.
Did I miss any setting in mach2? Thanks.
Alex
Old 04-19-2007, 01:21 AM
I managed to get a few things working with mach3 demo. But I am still having trouble getting the motor to turn correctly. At times it will turn the correct amount of turns corresponding to the length of linear travel as per the G Code. If I am correct, for a 4 inch travel, the motor should turn 80 times. At time it is but sometimes it is less. Funny. Anyone can help to explain where I am going wrong? Thanks.
Alex
Old 04-19-2007, 05:32 AM
ger21's Avatar
Try lowering the acceleration and velocity by half.
Old 04-19-2007, 08:16 AM
Isn't the acceleration and velocity control the speed at which the motor runs? If thats the case, then if I reduced the speed, the DRO will also show a reduced velocity of the read out, i.e. the numbers changes slowly. But the problem I am having is that on one occasion, it runs properly but then on another occasion it doesn't. Never realised there are so many uncertainties when using mach software. Or maybe just my setting not right.
Old 04-19-2007, 10:35 AM
Gerry I don't know about all situations, but in my own, the tuning was different between V2 and 3. Now that may have been due to the new set-up being slightly different as well, but my number would not work if I simply translate them across to the new xml.
Mike
Old 04-19-2007, 10:46 AM
Alexccmeister just remember that birthing always has pain, but the result is joy! For the money, you cannot find a better deal than Mach software. The support is #1 regardless of who you want to compare it to!
Can you be more specific on what you mean by the above quote, "But the problem I am having is that on one occasion, it runs properly but then on another occasion it doesn't." Are you meaning the machine runs at programmed speeds one time and then the next time runs as some other speed? Do you ever see changes within the program?
If you are getting good results some of the time but not others it is typically something causing problems with the pluse train or noise but if I remember correctly noise normally causes lost or gained pluses to the motors.
Do you have sreen savers? Gerry you would know more about this than I but could it be a program interferring with the pluse train?
Mike
Mike
Old 04-19-2007, 11:04 AM
ger21's Avatar
The reason I said to lower the velocity and accel was that perhaps you're trying to go faster than the machine is capable of and you're losing steps. Go much slower and see if it helps.
But, if Mach3 works fine, get rid of Mach2 and don't worry about it. That's the easiest solution. There's really no reason to use Mach2 over Mach3.
  #11   Ban this user!
Old 04-21-2007, 11:43 AM
JOHNKLEEPER is on a distinguished road
You Are Loosing Steps I Concur The Feed Rate In The Motor Tuning Dialoge Is Set To Hight Use The Motor Tuning Dialog To Set The Fed Per Inch To A Very Low Setting And Keep Incrementally Bumping It Up Until No Steps Are Lost.
  #12   Ban this user!
Old 04-21-2007, 06:36 PM
I got all the stuff sorted out.thanks for all your help. I managed to get mach2 and mach3 to run properly. I set the velocity to 60 and acceleration to 3. Thanks.
Mach2 to Mach3 not working...... Normsthename Mach Mill 3 01-23-2007 01:34 PM
whats the differance between mach2 & mach3 adam dogg General CNC (Mill and Lathe) Control Software (NC) 3 01-16-2007 11:08 AM
Choosing between Mach3, Mach2, or Mach1? cjchands Mach Mill 5 10-15-2006 11:07 PM
Mach2/Mach3 installation problem (laptop) xyz100 Mach Software (ArtSoft software) 3 07-25-2006 08:56 AM
BOSS retro w/Mach2 results: jderou Bridgeport and Hardinge Mills 11 04-20-2006 10:21 AM
