Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 04-08-2007, 01:55 PM
ints99 is on a distinguished road
Mach3 and Tool Setter
How to use Tool Setter w/Mach3?
1) What ToolSetter to use? Is TP100 ok? http://www.cadcamcadcam.com/index.as...PROD&ProdID=10
2) How should I setup Mach3 to take use of it?
3) What modification to G-code is needed?
Old 07-31-2010, 05:29 PM
Big-tex's Avatar
Big-tex is on a distinguished road
I have better solution for you that already works fine..
Read it here.
http://www.cnczone.com/forums/showth...=100594&page=9
Mach3/EMC2.0 compatible tool setter required ints99 Calibration & Measurement 0 04-08-2007 01:47 PM
What will cause this tool setter problem? Hogger Daewoo/Doosan 3 01-03-2007 07:52 AM
Setting up a Tool Setter. Smackre Mach Software (ArtSoft software) 6 06-16-2006 10:41 PM
50 taper tool setter utengineer04 Work Fixtures and Hold-Down Solutions 4 09-12-2005 02:16 PM
tool setter ACME General Metalwork Discussion 8 07-30-2005 11:15 AM
