Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 04-01-2007, 02:45 PM
Gold Member
InspirationTool is on a distinguished road
Goto Z's button... also the @#$%#$% wizard...
Hi all!
Some quick questions....
On the "Goto Z's" button on the first screen.... is there a way I can get that to go to X0, Y0, but NOT Z0? I can't edit the button script, as there doesn't seen to be a script for that button.
Also, is there a way to make that !@#$%@#$ wizard put out all his help text at once? It's painfully slow.
-Jeff
www.JeffAlbro.net/cnc/
Old 04-01-2007, 03:32 PM
ger21's Avatar
You can use the screen designer to change what the button does.
Old 04-01-2007, 09:54 PM
Gold Member
Thanks Ger! I'll check out the videos on the screen designer.
-Jeff
GOTO Z button TMaster Mach Mill 10 05-30-2009 07:18 AM
Nesting Wizard, Mach3 internal wizard. thuffner3 Mach Software (ArtSoft software) 1 03-04-2007 08:38 PM
configure run button xtihc Mach Software (ArtSoft software) 1 05-25-2006 04:57 PM
Emc color button essa LinuxCNC (formerly EMC2) 2 11-21-2005 08:19 AM
so that is what that button does johnm Test Forum 0 03-26-2003 03:43 PM
