Results 1 to 2 of 2
Thread: Mach 3 - Photo help
    Aug 2006
    Mach 3 - Photo help
    Once again I come to the CNC community for help. I am a weekend warrior when it comes to CNC. But it sure has been fun. I have seen many examples of photo carving out there and just as many software packages. (still evaluating those) I came across a statement in one of the Forums that said you could download a .bmp file into mach 3 and get a somewhat decent result. Thought I would give it a try today. PROBLEM
    1) When I loaded the .bmp into mach it did create the G code software. However, it seems to have set the Feed Rate at 6.0. At that rate I will be here all day. I typically import G code in from BobCad and run with a feed rate of around 120. I am guessing since this will not cut very deep .03" I can run much faster. How do I get from a feed rate of 6 to 120?
    2) Second question. Has anyone had good success cutting a .jpg or .bmp straight into mach. I've looked for some pictures on the site but have not found any. Can anyone direct me to some examples.
    Thanks for the help
    Mar 2003
    Shelby Twp, MI....USA
    1) Click the Edit g-code button and add
    F120 to the start of the code. You might also be able to just type 120 into the feedrate DRO.
    2) Look in the photo section of the Yahoo support group. Mach1Mach2CNC
    EDIT. I thought there were some there, but can't find them now. Sorry
  1. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 05:41 AM
  2. My first WIP CNC ...photo...
    By Calico in forum DIY CNC Router Table Machines
    Last Post: 08-19-2005, 04:34 AM
  3. A Photo
    By murphy625 in forum CamSoft Products
    Last Post: 02-25-2005, 03:01 PM
  4. Photo Gallery?
    By Mr.Chips in forum Forum Questions or Problems
    Last Post: 03-15-2004, 12:12 AM
  5. Photo Test
    By Mr.Chips in forum Test Forum
    Last Post: 01-19-2004, 05:36 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
