Results 1 to 11 of 11
Thread: Missing something... using edge finder thingy in offset screen...
    Gold Member
    Mar 2005
    While I'm waiting for my new mill to come in, I'm playing with Mach 3 on my desktop machine (no controller attached).
    If you go to the "offsets" screen, you can play with the offsets, obviously.
    Oh look, there is a nice looking edge finder thingy.... it looks like you type in the edge finder diameter, jog until you trip the egde finder, and then press the button for which edge you are touching... and I figure it SHOULD then set zero for whatever offset you are using, but those buttons don't seem to do anything. Changing the edge finder diameter doesn't seem to affect anything either
    What am I missing?
    Thanks!
    -Jeff
    Mar 2003
    Shelby Twp, MI....USA
    Did you hit enter after you entered the edgefinder diameter? If you don't hit enter the number won't take. This goes for anywhere in Mach (DRO's) that you can enter a number.
    I don't have a machine hooked up either, but if I enter a diameter of .5, the lower two buttons will set my current position to X -.25, Y -.25
    Gold Member
    Mar 2005
    Quote Originally Posted by ger21 View Post
    Yep, I saw that... That's not the problem...
    Those buttons don't do anything even when I have a diameter in the box.
    -Jeff
    Mar 2003
    If you go to the Operator menu, and choose "edit button script", do the buttons start blinking? If they do, click one and see if there is a few lines of VB Script in them. The lower right button should have this code in it.
    Code "G92.2"
    Call SetDRO(1, ABS(GetOEMDRO(1000))/(-2))
    Gold Member
    Mar 2005
    Ah-ho! The plot thickens!
    Indeed, the code is there, and when I press the "play" button for the code, the coordinates change to the desired result, but pressing the button on the screen does not activate the code.
    Thanks Gerry!
    Now, do you have any idea why the code isn't being run? Is there something I need to have turned on so that the buttons work?
    Thanks!
    -Jeff
    Mar 2003
    Out of ideas. I'd try reinstalling.
    Gold Member
    Mar 2005
    I did, and this time I included the driver. My machine hung on reboot so I had to remove it. I reinstalled it again without the driver and had the same behavior...
    When machsupport.com is back up I will go check there for ideas...
    Thanks!
    -Jeff
    Mar 2003
    I don't have the driver installed and mine works fine. I was going to mention that, but didn't think that was it.
    Gold Member
    Mar 2005
    I just reinstalled it again, this time with the driver, and I followed the instructions to reboot before using, and it worked fine.
    Thanks!
    -Jeff
    Apr 2005
    I was(still) having the same problem I found out that there is a bug in the offset page and you can contact Brian at New Fangled Solutions and he will send you a new file for that brianb@newfangledsolutions.com. Also click on the select button rather than the image of spindle. And I thought it was me.
    Sonny
    stumpys@ecis.com
    Quote Originally Posted by InspirationTool View Post
    What am I missing?
    Thanks!
    -Jeff
    Mar 2003
    I'll have to check on that. All my button scripts have ecently stopped working now.
    1. Question About Edge Finder
      By FLUTE HEAD in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 09-29-2008, 02:21 AM
    2. Has anyone used this edge finder?
      By l u k e in forum General Metalwork Discussion
      Last Post: 03-19-2008, 02:52 PM
    3. Laser edge finder
      By dave6 in forum Calibration and Measurement
      Last Post: 12-10-2006, 10:06 AM
    4. anyone know where to get this optical edge finder?
      By mbwittig in forum General Metal Working Machines
      Last Post: 10-24-2006, 02:33 PM
    5. Anyone have a edge finder G-code routine?
      By InspirationTool in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-02-2006, 08:48 PM
