Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 02-26-2007, 09:20 AM
CbrViking's Avatar
CbrViking is on a distinguished road
USB to Printer port compatability
Has anyone tried one of those USB to Printer Port adapters with Mach3 Mill? It's getting harder and harder to get PCs with a printer port, so I was just wondering...
Old 02-26-2007, 09:38 AM
ger21's Avatar
They don't work. But it's easy to get a PCI parallel port card that will work.
Old 02-26-2007, 09:48 AM
CbrViking's Avatar
OK, but that won't work for a notebook PC. I see a PCMCIA card printer port. Do those work?
Old 02-27-2007, 02:27 PM
civilseal is on a distinguished road
The reason they dont work is that they simulate a printer instead of a printer-port.
I bought one and tried, and I dont get a Printerport, but a new printer that is named usb-converter or something like that.
So I have to print to that, and then it communicates with the printer.
It seems totaly stupid to make it like that, like this the printer must be compatible with the adapter, and not all printers work.
Why not make it simulate a printerport, and there should be no problems?
The usb to serial adapters works like they should, i wonder why they had to make these different
Old 02-27-2007, 02:48 PM
CbrViking's Avatar
So then, in order to use a newer notebook PC, you have to invest in a newer motor controller, right?
Old 02-27-2007, 03:04 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
http://www.cnczone.com/forums/showth...light=usb+port
Old 02-27-2007, 03:40 PM
CbrViking's Avatar
WOW, now that's COOL!
Old 02-27-2007, 05:05 PM
ger21's Avatar
You could also use an ncPOD. http://ncpod.oemtech.com/ A mach3 plugin will be available shortly. I believe that a beta plugin is available now.
Adding a printer port Problem!!! mindstorm88 Mach Mill 8 09-18-2006 10:36 PM
printer port tester smarbaga General Electronics Discussion 1 12-10-2005 11:57 AM
Communications output to Printer Port kheri Post Processors for MC 0 03-26-2005 12:40 AM
printer port? replicapro General CAM Discussion 2 11-26-2004 03:37 PM
Have problems with G201 and printer port Christian Gecko Drives 2 09-26-2004 02:44 PM
