Having a problem with this gcode file when loading into Mach3... Tried on Mach3 Stable and development versions, same results. File displays in the path window as a bunch of circles for the toolpath... very strange. Posted in bobcad V21 with the Mach3 specific post. Basically, it's my daughters name in raised letters, with the background field milled to a depth of .2" Someone mind taking a look and see if they get the same results? Amanda.txt is the gcode file and Amanda.dxf is self explanatory :-) Also, gcode file displays correctly and simulates correctly in "simulate" on Bobcad. |
| Change the IJ mode in the general config.
I am running mach3 and using BobCad Art Prox. I am not seeing the problem in the program..they are just x&y moves. Here's my story. I am cutting a 3D sign that I programmed with BobCad Art ProX and set my step over to .03...this is when I started to have my issues. the program starts and cuts well and even the graphics look good...but around the 17 line or later the machine just takes off. My tool path is on a 45 deg. angle and it refuses to stop and continue on to the next line. It runs off in the 45 deg angle. Any one know if Mach3 has a problem processing this much info? |
| Are you using G41 or G42? I've seen that happen if using G41/G42 and lots of short line segments.
| Can you post 50 lines of code so I can see what it's doing?
| This has been re- posted. The problem seems to be gone now that the distance was changed to .06. The machine is running now. I need closer tool paths! If you see any thing let me know. I need to run a .125 ball nose and can't tighten the path. I don't want hand work! M5 M9 G0 G91 Z0. T1 M6 S0 M3 G90 G54 X0. Y0. G43 H1 D1 Z1.25 M8 X15.5287Y2.4688Z1.1 G01Z0.125F20. X15.5107Y2.4508F75. G41 Z0.3659 X15.5101Y2.4501Z0.3679 Z0.3693 X15.509Y2.4491Z0.3714 X15.5076Y2.4477Z0.3744 X15.5063Y2.4463Z0.3764 X15.5044Y2.4444Z0.3785 X15.5025Y2.4425Z0.3799 X15.5006Y2.4406Z0.3808 X15.4987Y2.4387 X15.4911Y2.4312Z0.3828 Z0.3834 X15.4904Y2.4305Z0.3839 X15.4898Y2.4298Z0.3848 X15.4884Y2.4284Z0.3864 X15.4857Y2.4257Z0.3884 X15.4843Y2.4243Z0.389 X15.4829Y2.423 X15.4802Y2.4202Z0.3897 X15.4788Y2.4189 X15.4775Y2.4175Z0.3891 X15.4747Y2.4148Z0.3877 Z0.3883 X15.474Y2.4141 X15.4734Y2.4134Z0.3897 X15.472Y2.412Z0.3913 X15.4693Y2.4093Z0.3933 X15.4668Y2.4068Z0.3943 X15.4644Y2.4044 X15.4619Y2.402 X15.4595Y2.3995Z0.3932 X15.457Y2.3971Z0.3917 X15.4564Y2.3964Z0.3925 X15.4558Y2.3958Z0.3931 X15.4546Y2.3946Z0.3942 X15.4521Y2.3922Z0.3957 X15.4497Y2.3897Z0.3965 X15.447Y2.387 X15.4443Y2.3843Z0.3959 X15.4389Y2.3789Z0.3948 X15.4382Y2.3783Z0.3954 X15.4376Y2.3776Z0.3959 X15.4362Y2.3762Z0.3967 X15.4335Y2.3735Z0.3976 X15.4308Y2.3708 X15.4227Y2.3627Z0.3958 X15.422Y2.362Z0.3964 X15.4213Y2.3613Z0.3969 X15.4199Y2.36Z0.3991 X15.4172Y2.3572Z0.403 X15.4145Y2.3545Z0.4062 X15.4118Y2.3518Z0.4089 X15.409Y2.3491Z0.4111 X15.4063Y2.3463Z0.413 X15.4038Y2.3439Z0.4144 X15.4013Y2.3414Z0.4155 X15.3964Y2.3364Z0.417 X15.3939Y2.3339 X15.3914Y2.3314Z0.4176 X15.3645Y2.3046Z0.4231 X15.359Y2.2991Z0.4238 X15.3563Y2.2963 X15.3536Y2.2936 X15.3522Y2.2922 X15.3508Y2.2909Z0.4243 X15.3481Y2.2881Z0.4251 X15.3454Y2.2854Z0.4256 X15.3206Y2.2606Z0.4273 |
You do have a G41. That's probably what caused your problem. G41/G42 don't work well with lots of short G1's.
#11
| What version of Mach are you ruunning, and do you have "enhaced comp" turned on? Some older versions had comp bugs, so a newer version might help.
| Radius problems when generating gcode from bobcad for mach3... ? | scyan | BobCad-Cam | 7 | 12-14-2006 12:33 PM |
| Bobcad V21.4 help file download | lakeside | BobCad-Cam | 1 | 08-04-2006 04:36 PM |
| BobCAD/CAM V21 and Mach3 Postprocessor | southernexplore | BobCad-Cam | 33 | 07-25-2006 12:28 AM |
| Mach3 xml file | Ed Williams | Mach Mill | 2 | 04-07-2006 07:50 PM |
