Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 01-06-2007, 07:12 PM
InventorJohn is on a distinguished road
Mach 2 loosing brains after loading gcode (Scale gets way off) Any Ideas
Hey Folks, I got a question. My homemade router is up and working, a few bugs to work out, but almost there, anyway I have successfully made a square and a gear So I thought I would try to make an image. I made a sample in the trial version of PhotoVcarve, but when I load the gcode into Mach 2, something weird happens. If I jog about an inch on the router, mach 2 shows about 4 inches, all 3 axes are screwed up, and it only happens when I load the photo gcode.
I have to exit and come back in. Any other file, its happy with. My question is what g-code can modify my settings so an inch ain't and inch no more?
Thanks!!
-John
Old 01-07-2007, 06:53 AM
ger21's Avatar
G20 G21
Old 01-07-2007, 10:11 AM
Thank you! I will give it a try. I don't know if I have any more hair to pull out
-John
Old 01-07-2007, 10:35 AM
ger21's Avatar
Using G20 and G21 is really not a good idea, according to Art. If your machine is set up in inches, make sure there is no G21 in the code.
Old 01-07-2007, 10:36 AM
ger21's Avatar
I meant that you shouldn't use G20 and G21 to switch between inches and mm.
Old 01-11-2007, 07:12 PM
Tony Mac is on a distinguished road
Hi John,
There is a problem with the default unit settings in our Mach inch postp as Ger21 mentioned.
If you send an e-mail to - support@vectric.com we can send you the fixed postp.
Sorry for the inconvenience this may have caused.
Tony
Old 01-12-2007, 10:42 AM
Thanks!
Thank you for the support info, it was driving me nuts. I tried to modify the code, but just ended up driving the bit into the bed before I could slap the e-off. Hey, the router just does what the computer tells it to
Thanks again,
John
