Results 1 to 3 of 3
Thread: Mach 3 router won"t move
    Jun 2005
    I've ben using Mach 3 for four days everything worked fine, came in this morning turned it on and the router won"t move. The screen shows everything fine , the windows on the screen show the router moving. I booted up mach 2 to see if the problem was in the table, but it worked fine.
    Does anyone have some advice for me..
    Thanks for any help Gary
    Jun 2006
    You left a lot out.......do you have power to your cnc machine?.........is your parallel cord plugged in?........is your "off line" button pushed on your screen?
    You might check to be sure the correct port is selected.
    Jun 2005
    I have power the plug is in the off line button has been checked in both positions and pins and ports are like they have been for the last 4 days, . It has to be in Mach 3 because Mach 2 works fine same mill and computer, just a matter of which icon I open.
    Thanks Gary
