Results 1 to 5 of 5
Thread: Compumill retrofit
    Sep 2006
    Compumill retrofit
    Hello ,
    I posted on another forum (FAQ Milling Machines) on this site but didn't realize until now Mach had it's own here. I have an early system 10 Dynapath driven Compumill with a control problem. I am looking into the problem but would like to find out if Mach 3 will drive the servos on a Compumill and what would I need to interface with it ? I have a stand alone computer I can use and Cam software. Thanks in advance for any help you might provide!
    regards,
    Dick L.
    Registered DennisCNC's Avatar
    Aug 2005
    Clearwater, FL US
    I'm guessing the mill is ~15 or more years old correct? What type of servos does it have (AC, DC Brushless, DC brush)? What brand of servo amps? They probably take +/- 10 control signal if so than you can use a converter board that will take a step/dir signal from Mach and convert it to +/-10 volt for the drive.
    Here is a link for the converter board:
    http://www.skyko.com/products/
    Dennis
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    Also, these old servos are likely to use resolvers for determining position. They will have to be replaced with encoders.
    Karl
    Aug 2005
    Clearwater, FL US
    ^^ True that!
    Dennis
    Sep 2006
    Dennis , They are Baldor motors , brushed ,25 amp , 450 oz in. That is all I could see at the moment. Karl I'm not sure on the encoder type. Thank you both for the info . I will know in a couple days if I need to go in this direction.
    Dick
  • Posting Permissions
