Results 1 to 5 of 5
Thread: Strange G03 problem
    Jul 2005
    UK
    Strange G03 problem
    Hi all,
    I've been having some problems converting DXF files to be cut in Mach. I'm using SheetCAM v4.0.0 and Mach3 v1.84.001.
    I've attached a sample DXF file, and the resulting g-code, and the images show the path in SheetCAM, and Mach's Toolpath display.
    For some reason, at line N0230 the G03 move causes Mach to take a large circular arc, but if I run the file through MicroTech's CncSimulator the simulated tool appears to behave as expected.
    The source of the DXF is a little strange - it's come from 3D Studio Max, and was exploded twice in ProgeCAD before being exported out as an AutoCAD v2000 ASCII DXF file.
    More complex files (with curved shapes) suffer from this problem very badly.
    So... is the problem due to something odd in the DXF, SheetCAM doing something strange, or Mach not interpreting the g-code correctly?
    Bit stumped on this one, so any help would be greatly appreciated.
    Attached Thumbnails Attached Thumbnails Strange G03 problem-sheetcam-display.jpg   Strange G03 problem-mach-display.jpg
    Attached Files Attached Files
    Mar 2003
    Shelby Twp, MI....USA
    Change your I,J mode to incremental. Depending on what version of Mach you have, it's either in Config>State or the newer General Config.
    Moderator HuFlungDung's Avatar
    Mar 2003
    Hey Gerry,
    You should add that answer to your signature. It seems like a common problem
    Jul 2005
    UK
    Doh!
    In my defence... I've just checked the post file for SheetCAM, and, of course, it states incremental IJ for Mach. The default MachMill config, of course, also has IJ set to incremental.
    The config file from which I based my setup has had that setting changed to absolute. I never touched it, honest!
    It looks good in the Mach toolpath now and simulates OK. Unfortunately, it's now well past 11pm here in Blighty, so I'm going to have to wait until tomorrow night before I can test it
    Glad it looks like I'm not the only one making that mistake though, thanks Gerry.
    PS I pointed Les (SheetCAM's author) at this thread. Les - if you're reading... hopefully sorted (as you can probably see)... cheers.
    Mar 2003
    Quote Originally Posted by HuFlungDung View Post
    Hey Gerry,
    I think that's twice this week, so far.
  • Posting Permissions
