Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 11-12-2006, 08:36 PM
gary7830 is on a distinguished road
From Mach2 to Mach 3
I've been using Mach2 for a few months (my only cnc experience) I want to go to Mach 3, but wander if I need hi tect help or is this a simple task. I like the ability to view the toolpath in Mach 3 and the Wizards.
Thanks for any help...
Gary
Old 11-12-2006, 08:38 PM
ger21's Avatar
Copy all your port and pin info, and enter it into Mach3. You'll need to retune the motors. You can keep Mach2 installed and install Mach3, just don't try to run them at the same time. That way you can keep using Mach2 until you get Mach3 setup properly.
Old 11-12-2006, 08:44 PM
I was under the understanding the pin config was different, I'm I wrong?
Old 11-12-2006, 08:54 PM
Do I only change the software settings or do I change the hardware pin locations?
Thanks for the help
Gary
Old 11-12-2006, 09:17 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
Make all your pin settings the same as they are in mach2, mach3 uses ipm so that will be a little different.
Old 01-03-2007, 02:59 PM
dart70ca is on a distinguished road
axes reversal in mach3
In mach2 I could just tick off which axes I wanted (to reverse the direction on) in a dialogue box. How do I do it in Mach3? The dialogue box for this function seems to have been moved or removed...
Keith
Old 01-03-2007, 03:08 PM
found it, thanks Art
Email from Art (fast):
"Config/homing and limits, check the 'REV' column."
Thanks,
Keith
Old 01-09-2007, 06:48 PM
Barker806 is on a distinguished road
The new version should see the Mach2 XML and ask you if you would like to have your XML converted I would double check all the settings but it should have very close!
