Results 1 to 4 of 4
Thread: Elapsed time in Mach 3
    *Registered User*
    May 2006
    Question Elapsed time in Mach 3
    Is there a way to fix the elapsed time clock in mach 3. I'm running the latest ver. of the program. It seems to run way behind. Maybe 10 seconds to one in Mach 3. Thanks in advance! Rev.
    Mar 2003
    Shelby Twp, MI....USA
    What kind of results do you get when you run the driver test? Something might be interfering with Mach3?
    *Registered User*
    May 2006
    can I ask what driver test your asking about? I can use the program and it seems fine while in use. It is just the time clock that seems to be so slow.
    Rev
    Mar 2003
    In the Mach3 folder, you'll find drivertest.exe or something similar. Run it and see what it says.
