Hi, I've attached a jpeg to make this easier (I was going to try to just describe the question without pictures. Given a block attached to to router table top and a project that is approximately symmetrical with respect to the y axis, the position 0,0,0 (home) is typically set at point "1" on the diagram (at least that is my understanding). Is there a problem, or will Mack3 have a stroke, if I want to set 0,0,0 at point 2 on the line of symmetry? Thanks
__________________ If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do? Steven |
| Steven you can set 0,0,0 anywhere on the table for mach3, but to do this you need the gcode to correspond using that same position on the model as your 0,0,0. At least that is my understanding of it, and my understanding may very well be flawed! Mike
__________________ No greater love can a man have than this, that he give his life for a friend. |
| go to the offsets menu, set the offset to 1 (G54) and hit zero at the zero you want on each axis. this is what you do if you home your machine every time. if not you can probably just zero the dro's on the mainpage. Jon
__________________ CNC Mini Lathe Plans and Rotary Table kits: http://jfettigmachines.com |
| I use Mach3 1.84 and have a followup question about zeroing Mach3. I regularly zero Mach3 by pressing the three "Zero" buttons on the Program Run page. The LED next to the DRO is red at this point. If I look at the offset page the G54 offset contains some non-zero value. OK, so I then start the program. My programs Do not contain any reference to fixtures, i.e. there are no G54s, etc. However, once in a while something goes awry and at least one of the axises will offset by the value shown on the offset page. Why does this happen and why is it not consistent? Is there a way to completely disable the fixture offsets? I never use them but they have messed up my programs before. I have started using the "Ref All Home" button which seems to allow the offsets to be zeroed along with the DRO but it would be good to hear from someone concerning the best practice. |
| G54 is the standard coordinate system in Mach3. Sorry, but I'm not sure why you're getting inconsistent results. You might want to try upgrading to a newer version.
| Let me revise my question and begin before the system even gets the gcode to mach Lets assume the same square piece pictured in the post #1 of this thread, and lets assume that you want the origin of the piece to be at point 2 on the diagram. Lets say that starting the cutting at this point is important for future alignment of the piece. Before sending the piest to RhinoCAM (and I am specifically specifying RhinoCAM in the question) does it make a difference how the piece is aligned in Rhino3D. on the piece Does 0,0,0 in Rhino3D have to be at point 2, or can it be someplace else, say point 1. Does this make an important dirrerence in generating the g-code or does the mach offset take care of this?
| Disclaimer: I don't use Rhino. You need to be consistent with your assignment of the origin in both your CAM and your setup. In other words, the origin of your actual stock needs to match the origin of your stock in your CAM. Select your origin based on what is easiest to setup. For example, I always the bottom left edge to work in the first quadrant and because of how I use a edge probe. Setting different origins in the CAM will affect the values in the G code but not the distances. I.e., all the operations will be shifted some amount but will still cut just as much. This can be compensated for by setting the DROs by negative of that amount if a mistake was made. Hope that all makes sense. |
Ok, I'll give upgrading a try. The same program will run fine most of the time but once in a while in the middle of the same program one or more of the DROs is shifted by the fixture offset amount. Obviously this is really dangerous if the machine is unattended. Is there a keyboard command that would cause this behavior? Perhaps EMI noise has caused that key to be "pressed?" Also, what significance does the small red/green LED next to the DROs on the Program Run page indicate? |
#10
Now the next question, and this is one you probably can't answer (not being a rhino user) and I will have to find out either from trial and error or maybe from asking the RhinoCAM folks. If my origin is set to one end of my line of symmetry in Rhino (point 2), when I start the CAM plugin, does it automatically pick up that origin from the CAD or do I specifically have to assign it myself?
#11
#12
Could be either, but you'll need someone with RhinoCAM experience to answer that. I'd think that it would default to the actual CAD file location, but the option to put it somewhere else (lower left usually) might be persistant.
