#25
| If you do a G53 X0 Y0 in MDI mode, you can then reset you're work offsets without getting wierd results.
#26
| Here is the offset page,as you can see by the arrows those are the button I'm selecting to set the offset. Is this wrong? In the edge finder dia box I put in .125 and then in the right hand corner it shows up .062 which is 1/2 of the edge finder dia. So far that is right but when you run the program it doesnt work properly. However I cant do any thing right now because my Z is not working properly (another problem to resolve ). In the MPG mode I tell it to go + and it goes - and untill I resolve this dead in the water.Sonny |
#30
#32
| It doesn't have to be, but it's an easy way to reset everything. Did you try it? Does it help?
#33
| Sonny |
#34
| Hi Steve: I was having the same problem I believe I would set the g54 offset in the lower left and when I ran the program it was always off in the "Y" axis and off as much as .250. I contacted Art and he didnt understand my problem. So I contacted Brian at New Fangled Soutions and he told me there was a bug in the offset commands. He also told told me that on the offset page to use the "select" button rather than the image of the spindle. Contact me at stumpys@ecis.com and I will send you the file or send you the contact info for Brian. Sonny
