Gday too all, I am playing with Mach 3 and bobcad 20. I am trying to make the eagle which is on this site. I have the post processor for MACH3. I use the profile to set up the pieces from the DXF file. The cutter will work around most of the radius but on occasions it cuts a circle back into the material with the correct radius. Any ideas on how to overcome this? TIA |
| Do your G2 and G3's use the R mode, or I,J?
| Have you tried changing your I,J mode in Config>State?
| I had this problem on a part that was all curves, circles and radiuses. The circles generated in the tool path were corrected easily (once I figured it out) by switching from G02 to G03 and vice versa on the offending arc. Working on the bottom of a part and having a overhead curve while going back and forth can throw ya a loop. |
| Can you post a sample of code with the problem?
