Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 08-25-2006, 04:34 AM
Greolt is on a distinguished road
Homing question
Mach 3 R1.84.002
I have homing switch position on the X axis at 100mm in from the left or zero end of the mill table
so that it is less distance to reference from middle work area. Saving time.
That switch is active if the table is already within that 100mm of the travel.
When referencing the axis goes in the negative direction looking for homing as it should.
Now acording to the PDF manual, if it is active it should look in the other or positive direction for home but it doesn't.
It just says "One or more homing switches are active....Please fix, then home"
Now what am I doing wrong? Is it a bug?
Thanks, Greolt
Old 08-26-2006, 10:45 AM
Don't know about R1.84.002 as I have upgraded now.
But there is a setting in Version D1.90.075 that will make this work as per manual.
Config / General Config / Home Sw Safety / Checkbox
All good now
