Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 06-07-2006, 01:00 PM
elogicca is on a distinguished road
MAch 3 questions
Ok i finally got around to setting up a 4'th axis, question can i use mach 3 mill or do i have to configure mach 3 turn? i will be using it to slot holes in cylinders.
Old 06-07-2006, 01:59 PM
turmite is on a distinguished road
You can use MachMill. You will have to configure the 4th axis in the setup just like you did your other axis. The units are set up as degrees and not as inches. In the config you will have to tick if the axis is rotary or linear. Tune the motor and away you go......ahhh if it were always that easy. This should give you a good overview of what you will need to do.
Mike
No greater love can a man have than this, that he give his life for a friend.
