Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 05-08-2006, 08:47 AM
bill south's Avatar
bill south is on a distinguished road
Talking More Mach3 Setup Questions
Top of the morning to ya ladies and gentlemen!!!!!!!!
Couple of quick questions for those successful and knowledgale in using mach3. I need to reverse my x and y axis motors and can't find the software setting to do that. It use to be listed under config in mach2 but low and behold, it is no longer there for version 3. What is the preferred method of reversing the motors. I'm using an encoder interace board so just switching wires may interfere with some of that!! Any suggestions????
Also, second question!!! I'm using a charge pump and want to disable the g320's. Can I wire the 3 position relay to apply 5 volts to the err/res terminal thus activate when the charge pump is active and to put a ground on the terminal when not active. I can't think of a reason why it wouldn't work this way. But, again, I'm just learning!
Have a wonderful day!
billyjack
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
Old 05-08-2006, 11:00 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
billyjack
1st question I know (Config - Homing/limits), but second i do not use.
Joe
Name:	motor reversial.jpg‎
Old 05-08-2006, 11:10 AM
bill south's Avatar
Thanks Joe!
Since I posted the question, I read a thread similar and they were discussing how in milling one should look at the tool moving and not the table. Guess it may be correct after all but only time will tell. At least enough time for me to figure out if I have a problem or not!!!!
Thanks again.
billyjack
billyjack
