#14
| I've run the code in a couple of simulators I have and it looks straight and valid. I would say you should re-check the motor tuning to make sure the pulses per unit are correct. Are you using steppers or servos? A mechanical problem can cause loss steps in x or y fairly consistently. |
#18
| Okay, I just ran a plain square (2"x2") and rectangle (1.5"x3"). Nothing fancy here but I still get a skewed cut. bottom left slants slightly in, bottom right slightly out. In addition I used a zig-zag cut pattern and about every third cut it jumped over one row (leaving a rough island). Also, the cuts in one direction were slightly deeper than the cuts coming back the opposite way. I ran a straight line down a piece of scrap wood approx. 30" long and then ran the cutter next to the line in the direction of the skews (the line on the scrap was aligned with the line cut in my waste top that is square with the gantry's travel). The cut was square to the line I had drawn on the wood when using the jog to transverse left to right. Last edited by jtriggs; 04-01-2006 at 09:23 PM. |
#19
| Have you tried increasing the pulse width?
#20
| Okay... first I've found the problem with the rough cuts on my square and rectangle. I programed the cuts using a 1/2" bit but, since all my other stuff has used a 1/4" bit, I forgot to switch bits. Duh. Anyway, I checked the pulse width. It was set at 1. I reset it to 4. The cuts are far cleaner but I don't really know if the pulse width change had anything to do with that. I assume using the proper bit is what accounts for that. There is still a slight skewing to the cuts but now it is the opposite of what it was before. |
#21
Hoping someone can help, not sure this is even the right place to post this... I have a problem with gaining steps, I have marked on the work crosshairs and this is my start point. Using Mach3, a short program (2 minutes) goes out, engraves its thing and then when it comes back to what Mach3 says is X,Y =0 it is out by just under 1 mm in both axis in the positive direction. It is not a sudden thing, this occurs over the course of the program. My guess is that noise is being generated from somewhere, affecting both the X and the Y but sheilding all the wires seems to have no effect. Hoping someone can please help, out of ideas and hair |
