I'm trying to run Mach 3 Mill in a simulation, and the execution times for simple programs are just plain silly- an hour and 30-plus minutes for cutting a 3-inch by 1.5 inch hole in half-inch plywood? I've got do be doing something wrong. But I dunno what. I've tuned the motors to match the 116-ounce motors on the machine, I've tred adjusting the feed rates, and they just keep reverting back to 1. Must be the drawing I imported, but it's a simple rectangle, how tough could it be? I've downloaded the latest pdf helpfle for Mach 3 I could find. Haven't looked at it yet but I'm headed there now. I just thought I'd ask here to see if anyone had any ideas. |
| Is there an F1 in the g-code?
| Could you post the g-code for that? Even with the feedrate at 1ipm, it should only take about 10 minutes.
| If you're importing a .dxf, set the speed in the import dialog box, use the layer button.
| Yes, there are two concurrent F1's in the first section of code alone, and several more down the line. Here's the first basic section: G90G80G49 G0 Z1.0000 G90.1 S1000 G0 Z1.0000 G0 X-97.0000 Y29.8333 M3 F1.000G1 Z0.0000 F1.000G1 X-97.0000 Y42.8333 G1 X-97.0000 Y43.5000 G1 X-97.0000 Y44.1667 G1 X-97.0000 Y44.8333 G1 X-96.8333 Y45.6667 G1 X-96.6667 Y46.3333 G1 X-96.5000 Y47.0000 G1 X-96.1667 Y47.5000 G1 X-96.0000 Y48.1667 G1 X-95.6667 Y48.8333 You can see I'm a total newb and am relying enirely on the conferters at this point because I won'tknow what I'm looking at until I learn a bit about the G-Code itself. I don't even think I know enough to ask intelligent questions. Here's a question: If I change that F1 to something like F40, will that change the feedrate to 40? |
| Did that, I lost the motor tuning though so it's still taking its own sweet time- over 30 minutes to cut about 9 inches! Appreciate the help, by the way. The toolpath that this converter is using isn't all that efficient, I can see some changes to make already |
| What might be happening is that the scale of the drawing might be way off, or the scale of the drawing and the scale of the Mach3 software are not the same. I need to find out where the machine limits are so I can see if the drawing needs to be scaled. |
#11
These look like they are in the ballpark for the 116 ounce motors on my machine, so I'm looking at the drawing scale, because my feedrate is at 100, and it's taking way too long to even plunge . |
#12
| I'm still learning Mach as well, but I think you missed what Gerry said: "If you're importing a .dxf, set the speed in the import dialog box, use the layer button. __________________ Gerry" There you can set the feed rates for plunge and direction, I think they default to 1 untill you change them, then they stay at what you set for the futer. The motor tunning should not matter to generate the G-code, it will generate what ever you tell it to, if your machine can't run that fast, well..... |
