#38
| How wide should it be. The .dxf is 241 inches.
#40
| I already did it at 4" wide. Try this. G0 Z0.13 G0 X3.66 Y1.47 Z0.13 G1 X3.66 Y1.47 Z-0.50 F30 G1 X3.75 Y1.47 Z-0.50 F100 G2 X4.00 Y1.22 Z-0.50 I0.00 J-0.25 G1 X4.00 Y0.69 Z-0.50 G2 X3.75 Y0.44 Z-0.50 I-0.25 J0.00 G1 X3.66 Y0.44 Z-0.50 G1 X3.66 Y0.25 Z-0.50 G2 X3.41 Y0.00 Z-0.50 I-0.25 J0.00 G1 X0.59 Y0.00 Z-0.50 G2 X0.34 Y0.25 Z-0.50 I0.00 J0.25 G1 X0.34 Y0.44 Z-0.50 G1 X0.25 Y0.44 Z-0.50 G2 X0.00 Y0.69 Z-0.50 I0.00 J0.25 G1 X0.00 Y1.22 Z-0.50 G2 X0.25 Y1.47 Z-0.50 I0.25 J0.00 G1 X0.34 Y1.47 Z-0.50 G1 X0.34 Y1.66 Z-0.50 G2 X0.59 Y1.91 Z-0.50 I0.25 J0.00 G1 X3.41 Y1.91 Z-0.50 G2 X3.66 Y1.66 Z-0.50 I0.00 J-0.25 G1 X3.66 Y1.47 Z-0.50 G0 X3.66 Y1.47 Z0.13 G0 Z0.25 G0 X0 Y0 M30
#41
| Make sure your I,J mode is set to incremental in Config>State
#42
| That's definitely much more like it in performance. Thanks for your efforts, Ger. I need to figure out why the scaling went wacky in the conversion, because the drawings are 1 to 1 and I told the conversion to go 1 to 1 as well. I'll go see if a 1 to .1 conversion will do the trick. |
#43
| Getting g-code from a .pdf is not a good way to do it. Notice how many lines of code you had vs what I had. Learn to use a cheap or free CAD program like A9CAD, www.a9tech.com , and you can do something that simple in a few minutes.
#45
| I definitely agree. I have CADSt lite, and A9CAD as well. My problem is I can't draw a straight line with a ruler ![]() I have PDF's of what I want to cut in the dimensions I need them cut in, but you're right, I need to go back to square one and learn to use the proper tools. |
