Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 08-27-2003, 03:06 PM
Jcadwell is on a distinguished road
Master5 Taig Mill Setup
Does anybody have experience setting the Taig Tools CNC controller up for use with Master 5?
The Master 5 pinout assigns pins 2 and 3 of the DB25 parallel port to be step and direction.
The Taig controller (MPS PRO) uses pins 2,3,4, and 5 to control what it calls X1, X2, X3, and X4.
The Master 5 program will only allow me two pins for control output. The Taig controller expects 4...
Is there a way to do this? Thanks very much.
Old 11-08-2003, 01:51 PM
tpworks's Avatar
tpworks is on a distinguished road
sounds like your controller uses phase control and master5 uses step/direction control I don't know if Master5 will do phase output.
Old 11-08-2003, 06:53 PM
Stevenpats is on a distinguished road
My controller required step + and - along with Dir + and -, I simply used the common from parallel port for the - on both, works fine. I was thinking I would need diode across the - from the controller, but no problems or smoke yet.
Hague
Taig Mill, US Digital MS23, Controller??? marjamar Taig Mills & Lathes 3 02-07-2007 10:16 AM
Taig mill accuracy dberndt Taig Mills & Lathes 14 12-28-2004 10:36 PM
New Taig in mind help on setup please mdoan General Metal Working Machines 0 10-25-2004 03:16 AM
Total Newbie on Taig CNC Mill!! vwgo Taig Mills & Lathes 2 10-17-2004 08:40 PM
Taig CNC ready setup help?? efreak Taig Mills & Lathes 2 08-24-2004 08:30 PM
