Hello folks
I have a problem with my "A" axis being used by featurecam.
If I give an "A" axis command manually ie: g00a180 the rotary table moves to 180 degrees
BUT if I draw a part in featurecam,the code from featurecam gives all the correct movements except it will not give any "A" commands. I'm using the post processor I down loaded from here, Version 1, its the only one I can find to go from Featurecam to mach 3 I guess it would help if I put the machine in here. I'm running a shopmaster bridgemill
Can someone help?
LinkBack URL
About LinkBacks
