Results 1 to 2 of 2
Thread: More CV questions
    Dec 2011
    Texas
    More CV questions
    I am looking for info on the CV function in Mach 3.
    I have a 5x10 router used mainly for cabinet work and as such I need good square corners in most of my cuts. When I first started corners were being rounded and I ended up turning the CV function off.
    Since then I have started doing som 2.5D V carving and was having problems getting smooth curves, turn the CV function back on and all is well.
    I have read what I can find on the Mach3 site but don't understand how to use the parameters for the CV function to be able to get square corners and smooth arcs without turning it on and off.
    Thanks, Jeff Smith
    Mar 2003
    Shelby Twp, MI....USA
    In General Config, turn on "Stop CV on Angles >" and set it to 89 or 90. Turn off all other CV options.
  1. CNC mill questions - thrust bearings, leadscrew mounting, general questions
    By tonofsteel in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 04:42 PM
  2. Brass vs Aluminium Vs Steel, questions, questions and questions...
    By alexccmeister in forum General Metal Working Machines
    Last Post: 08-15-2011, 01:40 PM
  3. More VSD-e questions
    By scrambled in forum Granite Devices
    Last Post: 12-13-2009, 04:17 PM
  4. New here with questions
    By whitehedr in forum Benchtop Machines
    Last Post: 05-25-2009, 05:26 PM
  5. New guy here and have some questions
    By Westjet9717 in forum DIY CNC Router Table Machines
    Last Post: 09-20-2007, 04:04 AM
