Results 1 to 4 of 4
Thread: Mach3 question
    Registered LouF's Avatar
    Sep 2011
    Mach3 question
    I have a question I have looked have did a search without any luck.
    On Mach3 the MDI Alt2 screen there is a button that says Verify when I push it I get a reading X -000.00 Y -000.05 Z000.21 what does this stand for the Video says something about verifying steps but nothing else are my readings good or is this of any use the machine is running good?
    Lou
    http://www.cnczone.com/forums/diy-cnc_router_table_machines/140832-new_fla-100_kit_build.html
    Mar 2003
    Shelby Twp, MI....USA
    Do you have home switches on your machine?
    I believe that Verify will re-home your machine and tell you if you've lost position since the previous homing routine.
    Sep 2011
    Gerry, yes I have home switches and limit switches I am re setting everything up my PC crashed last week and lost everything..
    Lou
    Sue
    Sue is offline
    May 2012
    spindle controler dosent work please help
    I have Mach3 and I cant get the spindel controler to work. When testing the spindle button (turning on the spindle function) in the Mach3 software. I am not getting the4.95 and 5.05 VDC . this testsall of the ISS-02 base circuitry. Can you help?
  1. Mach3 question
    By 4lowie in forum Australia, New Zealand Club house
    Last Post: 09-29-2011, 08:41 AM
  2. Mach3 Question
    By binfordw in forum Benchtop Machines
    Last Post: 12-14-2010, 04:09 PM
  3. mach3 question?
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 09-18-2009, 12:35 AM
  4. Need Help!- G-251/Mach3 question
    By alphamail in forum Gecko Drives
    Last Post: 11-06-2008, 04:14 AM
  5. Mach3 question
    By cosmynnec in forum Mach Software (ArtSoft software)
    Last Post: 05-01-2006, 02:46 PM
