Results 1 to 4 of 4
Thread: Mach3 downloading problem
    May 2007
    I am having trouble downloading Mach3. It is an older computer 996mHz. I tried saving to the desktop and the file size is only 254kb which only took a micro second and that seemed odd. That file also won't run.
    I tried downloading legacy Mach programs and that worked fine.
    Any suggestions out there?
    Thanks,
    Pat
    Registered rockcliff's Avatar
    Dec 2006
    canada
    I would try to re-download the lock down version, could just be a bad copy
    Rockcliff Machine Inc.
    www.rockcliffmachine.com
    May 2007
    Thanks Rockcliff,
    I tried downloading again and it worked. Now I am trying to get the "reset" to stop flashing. I just click it on my other computer running a Gecko stepper
    machine and it stops flashing. It doesn't have an Estop button/system. I sort of recall when I frst set it up I had to do something special, but my memory is lacking (getting old). Maybe I shuld check out the manual.
    Thanks,
    Pat
    May 2007
    Rockcliff,
    I searched for "reset problems" and ger21 had the answer. Set the estop config to active low. That is what I had to do before.
    Thanks Rockcliff and ger21 for all the great info in this forum.
    Pat
  1. data downloading pc to cnc problem in 0MC/0MD fanuc system
    By vk_rathi in forum General Metalwork Discussion
    Last Post: 04-07-2009, 07:40 AM
  2. Downloading Programs
    By chucker in forum Fanuc
    Last Post: 10-14-2008, 09:02 AM
  3. downloading programs....
    By REVCAM_Bob in forum Fadal
    Last Post: 10-11-2008, 08:17 AM
  4. Downloading large files
    By moldcore in forum Milltronics
    Last Post: 05-09-2006, 11:10 AM
  5. Uploads for downloading
    By CNCadmin in forum CNCzone Site News and Contests
    Last Post: 07-23-2004, 11:15 AM
