Results 1 to 4 of 4
Thread: Mach3 External Estop Request Wont Go Away No Matter What
    Feb 2011
    us
    I've almost got my first cnc router up and going. then all of a sudden one day Mach3 started to say "external E-stop requested" even when i take button off the breakout board. i have checked everything i have checked and unchecked the ActiveLow setting with no effect at all. also i have tried just to uncheck the estop button in inputs but it wont stay off. i have even uninstalled and then reinstalled but it still comes up. even if i hit the reset the warning goes away for a second and then comes back. it was working for a few weeks when i was doing testing but now i cant move anything.
    Please Help i really want to get this up and running.
    Feb 2011
    us
    so i messed around with it a little more today and what i have found is my y axis works totally fine but when i try to move my x to the right the z moves and then the estop comes up. when i move the x to the left the right motor works but the estop still comes up.
    Registered LZ1TWB's Avatar
    May 2006
    Bulgaria
    Try to add debounce in general config or add a capacitor across the button.
    I have never had any problems with my setup, because I have my E-stops and limits wired in series at 24V driving relays. It is fully immune to this kind of problems. Maybe you should try to make a change in your schematic.
    Jul 2006
    Hungary
    Exclamation
    Use optical isolator (optocupler) to inputs, and no more problem.
    Hazard is come in GND.
  1. Need Help!- Mach3 ESTOP. Instant or decelerates??
    By neilw20 in forum Mach Software (ArtSoft software)
    Last Post: 08-20-2011, 07:38 PM
  2. External EStop Requested Issue
    By restos in forum Mach Software (ArtSoft software)
    Last Post: 10-11-2009, 09:49 AM
  3. "External Estop requested"
    By phantomcow2 in forum Mach Software (ArtSoft software)
    Last Post: 01-01-2007, 09:55 PM
  4. Mach3 External Estop Reset
    By bcromwell in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2006, 11:16 PM
  5. Mach3 External Estop Requested
    By WarrenW in forum Mach Software (ArtSoft software)
    Last Post: 12-18-2005, 10:56 AM
