Is their a way to charge the sequence of the go to zero's? When I hit the goto zeros button the Y and the x axis move than once they get to 0 the z goes up. That is a bad thing if you have the but in the work. I'm I using the goto zeros the right way or should I be using the home, button?
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| I think in the config/state (or is it logic), there is a selection "use safe Z". Check this and the Z should move first up to a preset positon determined in the "settings" screen down in the lower right quadrant of the screen. You can set this DRO by entering in your desired safe Z height. |
| Go into screen designer, and change the button. Double click on it, and when the window opens, choose the execute VB Script. In the window, enter the following. code "G0 Z0" code "G0 X0 Y0" Save the screen, and that's it. Back up the screen first, just in case.
| Brian, what does the G53 do in this instance?
| You mean instead of where the user may have set Z=0, just to be safe?
