Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 11-14-2005, 04:32 AM
Lionclaw's Avatar
Lionclaw is on a distinguished road
Mach3 Mill Pausing Problem
Starting tonight, my machine seems to be pausing after each revolution of a helical cut.
G0 X0.4680 Y0.8020 Z0.2500
G1 X0.4680 Y0.8020 Z0.0000 F10
G2 X0.4680 Y0.8020 Z-0.0671 I0.0000 J-0.0200 F25
G2 X0.4680 Y0.8020 Z-0.1343 I0.0000 J-0.0200
G2 X0.4680 Y0.8020 Z-0.2014 I0.0000 J-0.0200
G2 X0.4680 Y0.8020 Z-0.2686 I0.0000 J-0.0200
G2 X0.4680 Y0.8020 Z-0.3357 I0.0000 J-0.0200
G2 X0.4680 Y0.8020 Z-0.4029 I0.0000 J-0.0200
G2 X0.4680 Y0.8020 Z-0.4700 I0.0000 J-0.0200
It will do one loop, pause for an instant, another, pause...
Anyone have any ideas?
Andy
CNC Kits - http://www.comptonsoft.com/cncweb/
Old 11-14-2005, 07:41 AM
ger21's Avatar
Did it work OK before with similar (or the same) code? Try it using the half circle code (Output 180°). Does it do the same thing? I only run Mach3 in simulation mode, and have never seen a pause.
Old 11-14-2005, 11:00 AM
mark c's Avatar
mark c is on a distinguished road
Are you running exact stop or constant velocity? Exact stop will do this.
Insanity "doing the same thing and expecting a different result"
Mark
www.mcoates.com
Old 11-14-2005, 11:49 AM
ger21's Avatar
I didn't even think of that. I bet that's it too.
Old 11-14-2005, 11:59 AM
Lionclaw's Avatar
Ah, good info. I might have accidentally changed a setting. I'll see if I can figure out how to change it back.
Andy
Old 11-14-2005, 12:16 PM
ger21's Avatar
It's under Config>State I think, or put a G64 at the start of the code.
Old 11-14-2005, 01:05 PM
Lionclaw's Avatar
Yay! That was it. Thanks guys.
I don't know how I did that. Must be a button on the interface somewhere I hit.
Andy
