Results 1 to 1 of 1
Thread: Repeatable arc cutting issue
    Oct 2010
    When I try to cut the roadrunner the second outline always ends up about 1/2" off in the Y axis.
    When I try to cut the attached machine check pattern I created, everything's perfect until the first circle is cut. The first quarter of the circle cuts fine and then the second quarter ends up being a straight line along the x-axis. The tail end of the second quarter (like the last 1/16") cuts and then the last half of the circle completes fine. Clear as mud...good. Once this happens, the remainder of the pattern is about a 1/2" off, but cuts OK.
    I attached a picture of what I'm try to explain.
    I've already changed the IJ Mode to Inc, which fixed a lot of arc cutting issues. But these two issues have above have been the same no matter what the IJ Mode is set to.
    I've attached my machine check pattern if someone could take a look, that would be awesome.
    Thanks,
    Dennis
    Attached Thumbnails Attached Thumbnails Repeatable arc cutting issue-img_20120209_112806.jpg
    Attached Files Attached Files
  1. Cutting out a cylindrical overlay issue
    By compunerdy in forum SprutCAM
    Last Post: 07-29-2011, 03:27 AM
  2. pocket cutting issue
    By jimmiethekid in forum Musical Instrument Design and Construction
    Last Post: 05-18-2010, 12:20 PM
  3. Repeatable Z when using collets
    By KyleL in forum DIY CNC Router Table Machines
    Last Post: 12-04-2009, 01:06 PM
  4. Mazatrol T4 goove cutting issue
    By ap-machine in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-10-2007, 08:33 PM
  5. How repeatable is homing?
    By 1ctoolfool in forum Haas Mills
    Last Post: 03-10-2007, 05:01 PM
