Results 1 to 2 of 2
Thread: Problems with my first cut
    Oct 2011
    Just got my Joe's 2006 up and running and tried to make my first cut. I developed a lettering toolpath in Aspire, saved it for post processesor Mach2/3 Arcs (inch)(*.txt). When I loaded this into Mach 3 it looked great on screeen but when I ran it the alignment was off (picture attached) - the lettering is supposed to be nice and even on two lines. I don't think it's my machine itself since each letter came out correctly which makes me think it's software realated.
    Any advise would be very much appreciated.
    Alan
    Problems with my first cut-first_cut.jpg.
    Apr 2004
    Oakland CA USA
    It looks like you're losing steps
    on the vertical axis. The letters look okay because the step loss isn't happening during the cutting of the letters, but somewhere in between. Try lowering the vertical axis' velocity and acceleration; it will go a little slower but (hopefully) will be accurate. You might also check for stickyness or play in that axis - a little mechanical problem, like rust on a slide, can cause that, as well as a pulley or screw that's a little loose.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
  1. Problems with 201
    By bryanrabb in forum Gecko Drives
    Last Post: 12-30-2007, 09:16 PM
  2. Problems with P#s
    By designpct in forum Okuma
    Last Post: 12-03-2007, 07:31 PM
  3. Arc problems
    By nda22 in forum Mach Lathe
    Last Post: 07-03-2007, 08:19 AM
  4. Run from here problems?
    By CNCadmin in forum Mach Mill
    Last Post: 11-30-2005, 10:38 PM
  5. More problems
    By Cold Fusion in forum Gecko Drives
    Last Post: 09-09-2005, 02:19 AM
