Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 12-19-2011, 11:01 AM
ducati955 is on a distinguished road
Question Error Message
I am running Mach III Mill R3.043.22
After I home all 3 axis (using Homing switches) The Normal/Abnormal LED
flashes and reads " Axis not referred to as Normal".
I can dbl click and clear the error message and accept the default.
Is there a setting I can change to prevent this?
Is a newer version of Mach available and any problems upgrading and
Keeping all my settings?
Ken
Old 12-19-2011, 11:02 AM
addition
Sorry, I am also started using Screen 2010 latest version.
thanks
Old 12-19-2011, 08:14 PM
ger21's Avatar
The abnormal LED is not an "error". It just means you have something set differently then you once did. I don't know who's idea it was, but it's more a pita than anything.
One simple fix is to just remove it from the screen.
However, if you're using my 2010 Screenset, there is no abnormal LED, so you don't have to worry about it.
Error Message tz1238 SolidCam 4 08-24-2011 01:53 AM
NX5 Error message FatFingers UG NX 1 08-09-2011 11:14 AM
Problem- "master encoder state error" AB ultra100 error message ShapeShaver Servo Motors and Drives 2 08-06-2011 06:39 AM
Need Help!- Error message CR1 etc. NPI Bridgeport and Hardinge Mills 8 09-24-2010 09:34 PM
G83 error message HBFixedGear Fadal 14 01-30-2007 09:42 AM
