Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 09-17-2011, 01:07 AM
landslide is on a distinguished road
possible to use 4th axis this way?
I would like to find out if it is feasible to use a rotary table to create a part that is otherwise too large for a small mills Y-axis movement.
can MACH3 control a rotary table to cut a 2D star shape with rounded apex's?
Old 09-17-2011, 08:27 AM
neilw20's Avatar
neilw20 is on a distinguished road
A lot of things are possible, but I need to upgrade my imagination before I can be of assistance.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 09-17-2011, 04:29 PM
lol yeah it is a bit hard to describe and I'd have to draw up some diagrams.
Old 09-17-2011, 05:09 PM
any tips on uploading a image? I tried creating an album in my profile but I can even get a tiny black and white image, you can see, to meet the file size restrictions. for some reason I only have 1kb of space but the image size can be 90odd kb.
Old 09-17-2011, 05:27 PM
doorknob's Avatar
doorknob is on a distinguished road
How about using a service such as photobucket instead?
(that's the way that I've always embedded photos into my threads, anyway)
Old 09-17-2011, 10:13 PM
ok. this is just a made up shape to try and explain the concept. the over all geometry may not allow for the process in all situation's but helpfully it is enough to explain what I have dreamt up.
assume that I want to make a shape with convex and concave curves all at tangents to each other so it is smooth. the item would be made out of 10-20mm plate. It could be water cut to shape and just a clean up milling step or a full milling out of the shape from a square plate.
assume that the plates dimensions just exceed the Y axis capabilities of the mill no matter what way you mount the plate to the table. you could make it by repositioning the job in a 2 step milling process.
however I would like to see if you could utilise a rotary table to make it in one fixture.
mount the rotary table so the axis is along the Z and offset on X to one side of center. the plate would rotate on top of the table. Only half the diameter of movement would be needed out of the x axis and minor movement in the Y axis to cut the curves.
you wouldn't want a shape that hit the column or would require the table to reverse rotation at any point.
I guess you would need a fancy cam package to program the tool paths if at all possible?
Old 09-17-2011, 10:23 PM
neilw20's Avatar
I have machined a 40" diameter 3" plate on a 20" Y travel machine. (X=48, Z= 20)
I just rotated it manually, indexed on pre made marks.
Big (well it was for me) wood chipper disk.
It was on a tilt table to boot, so made angled cavities for knife blades.
We did 4 or 5 of these. 2 days machining, each. 12 blade slots.
Sure you could do it with a rotary table, but stability on the unsupported areas needs some clamping, or Z chatter will become very apparent.
Old 09-17-2011, 11:06 PM
well that's encouraging.
I wouldn't be expecting miracles in terms of finish. I'm really only considering this as I can only justify purchasing a small machine for hobby use, that would be 20mm to small on the Y for a couple of designs I currently get water cut then finish on a manual mill.
in terms of programing is it feasible for a MACH3 stepper motor mini mill or impossible unless I have a cam package worth 3-5 times the mill?
Old 09-18-2011, 06:02 AM
ger21's Avatar
Use the "Go Advanced" reply option, and then the "Manage Attachments" button, and you can upload images into the post.
Old 09-18-2011, 07:28 AM
Torsten's Avatar
Torsten is on a distinguished road
Possible Yes, Mach3 should have no problem with this.
As you expect finish would suffer a bit.
Problem is the Postprocessor for such a Machine configuration.
I have seen Industrial prototype Machines with just a X,Z and B Axes.
Where any shape of contour could be machined by sliding the x-axes and B-Rotational Axes in sync.
Usually the Programs will be a bit longer because of the many Blocks required to describe the path.
Programming this by hand would be very difficult.
And a custom Postprocessor is likely not cheap.
Two Servo 3000 CNC Milling Machines 4 Axis and 3 Axis CNCadmin EBAY ADS 0 07-29-2011 04:40 AM
Problem- a problem with slaved A-axis moving properly relative to Y-axis zool Mach Software (ArtSoft software) 34 07-05-2011 09:45 PM
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
