Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 09-05-2011, 06:59 PM
vmeek is on a distinguished road
Mach 3 problem
I think I have more of a mechanical problem than a sofware problem but here goes.
I am using Mach 3 and if I zero my xyz axis and load a cutting g code in my router the code rtuns but the xyz axis does not return to zero.
I have entered 2 different codes and the failure remains the same/not returning to zero.
I think the problem is a weak power supply.
The step motors will stall and the g code count will be off causing the zero point to be off.
Tell me what you think.
vic
Old 09-06-2011, 12:43 PM
Claude Boudreau is on a distinguished road
Red face
vic
You seem to say that you can zero your axis before running your g-code,why would a weak power supply dont make it stall then...
Does it home when you press the home button?
When your motor are not locked-up can you turn the axis freely by hand?
Is there a g-28 towards the end of the code?
Old 09-06-2011, 01:42 PM
hub hub is offline
hub is on a distinguished road
Might be this simple.. or not.. but here goes:
Press "ref all home", then zero each axis..
http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html
Mach 3 Problem juniormint General CNC (Mill and Lathe) Control Software (NC) 1 07-23-2010 09:05 PM
mach 3 problem ellard Machines running Mach Software 4 04-15-2009 06:53 PM
mach 3 problem ellard Canadian Club House 1 04-15-2009 12:01 AM
Help! anybody have this problem w/ Mach 3? sconklin Mach Mill 6 09-18-2007 06:54 AM
Anybody had this problem in Mach 3? pointcloud Mach Mill 3 07-13-2007 08:09 AM
