Results 1 to 9 of 9
Thread: Why is pin no.4 not lit?
    Nov 2009
    Hi guys,
    I'm trying to set-up a new Gecko G540 in Mach3. I'm able to jog in all directions, except Y where it only travels in +Y. When I look at the DIAGS screen, I can see that the pin 4 which controls Y DIR is not lit. I checked the continuity in the cable and it's ok. I even checked the internal header cable from the motherboard to the connector in the back of the PC and it,s OK. The port is set to EPP. Any ideas ?? Could the Gecko be defective and not receive/send back signal on that pin ?
    thanks!
    P.S I double-posted this message in the Gecko drive forum
    Feb 2007
    Smile
    Quote Originally Posted by Frederic Gagnon View Post
    Hi guys,
    thanks!
    You must have double check section 5.3 right?
    http://www.machsupport.com/docs/Mach...all_Config.pdf
    Nov 2009
    Quote Originally Posted by Claude Boudreau View Post
    Yes, I have used the Gecko xml file and double-checked the output values.
    Meanwhile, I have decided to install Mach 3 on another older, dedicated PC. I have finally been able to get control of the stepper driver, but the PC will freeze from time to time.
    Went through the Windows XP optimization, disabled ACPI in the BIOS, still freezing....
    Feb 2007
    Red face
    Do you still have the no.4 pin unlit with the older pc?
    I dont have gecko but my diagnostic page show only pin 4 and 8 lit.
    I would look for a program working in the background (as internet ,screen saver,anti-virus...)
    This search result might be of some interest: http://www.cnczone.com/forums/mach_m...=mach+freezing
    Nov 2009
    Hey Claude!
    I uninstalled every software on the system except Mach3, including anti-virus and the firewall (it's not connected to internet). Cleaned up the startup sequence as well. So I did some tests earlier with that setup, and still freezes randomly (needs reboot).
    Basically, by changing PC I fixed my pin no. 2 problem, but got a new one!
    Possible solution : I just found out that Artsoft highly recommends using a graphic card that is not integrated on the motherboard, and this old pc was ripped of all extension cards and is running on the internal video..ahah! It seems the motherboard can't drive at the same time a video card and the high speed pulsing in parallel port.
    Will try to find an old AGP video card somewhere to see if that is the cause.
    Regarding your question, I think I had 4 pins lit in the diags window (like 6 thru 9) but not sure. will check tomorrow.
    Merci
    Nov 2009
    EUREKA!!!!!!!!!
    Adding an "external" graphics card fixed the freezing!!
    now the fun begins...
    Feb 2007
    EUREKA!!!!!!!!!
    Just a quick follow up here , on your diagnostic page witch pins is highlited now?
    Glad to see you've fix your problem.(to freeze is no fun)
    salut!
    Quebecois?
    Nov 2009
    Here's a screen grab. Much less pins are on.
    (je suis à Bécancour, anciennement Montréal...)
    Attached Thumbnails Attached Thumbnails Why is pin no.4 not lit?-mach_diag.jpg
    Feb 2007
    Looks more like mine now.Not sure why only 2 lit...
    Acadien du nord du Nouveau-Brunswick
  • Posting Permissions
