Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 08-17-2011, 07:43 PM
woffler is on a distinguished road
Spindle pulse feed back out of control
I have a cnc 4pc c-3 board with a interrupter using a single hole disk .Any way the problem is the feed back rpm bounces all over the place and is totally unusable . I have the spindle speed averaging checked and the use the spindle feed back in sync modes checked i have spindle pulley set to 1 and use spindle motor out put checked as well as pwm. control, i get a good pulse as i have a led hooked to the pulse stream. Any one have any idea where i might be going wrong . Thank You
Feed Back Farmers Machine CamSoft Products 1 10-19-2010 07:59 PM
Pulse Motor for Auto Feed? EvilSmirk Mini Lathe 1 09-15-2009 10:48 AM
Spindle RPM control - Do I need an index pulse? Lexx0001 LinuxCNC (formerly EMC2) 8 03-27-2009 01:42 AM
Problem: Feed back on Screen from Spindle northstarr Haas Mills 2 06-28-2008 09:02 AM
