hi..i'm very new in cnc mill and actually i'm building a mini 3 axis cnc machine with mch3 software. my question is ...is it possible to disable the work offset of mach3? so it will always use the absolute machine coordinate. Thank you |
| Just go to the offsets page and enter zero's for the offsets, and save. Be aware that zeroing an axis will add an offset to that axis. What I do is use the Home Offsets in Config > Homing Limits to specify my 0,0 location. After I home the machine, it's ready to run with a permanent 0,0 location.
| i tried to zero all the offset coordinate and absolute machine coordinate, but when i load a gcode and run it, the Z coordinate suddenly change to 50. how it can be? Before run the program ![]() When program running, after x & y reach the coordinate in the g-code, the z coordinate suddenly change to 50. ![]() is there any think wrong with the gcode? below is the gcode.... (BEGIN PREDATOR NC HEADER) (MACH_FILE=3AXVMILL_MM.MCH) (MTOOL T1 S1 D3.175 H127. DIAM_OFFSET 1 = 1.587) (SBOX X0. Y0. Z-25.4 L81.204 W72.246 H0.) (END PREDATOR NC HEADER) % O100 (PROGRAM NUMBER) (PROGRAM NAME - BOBCAD1.NC) (POST - MACH 3 MILL NO ATC METRIC) (DATE - MON. 08/08/2011) (TIME - 09:39PM) N01 G21 G40 G49 G54 G80 G90 G91.1 (JOB 1 ENGRAVING) (FEATURE ENGRAVE) (N02 T1) N03 S1497 M03 N04 G00 G90 G54 X45.294 Y69.74 N05 G43 H1 Z2.54 M08 ------> in this line the Z change to 50... N06 G01 Z-1.27 F300.5544 N07 G03 X32.428 Y39.521 I10.91 J-22.494 F304.2574 N08 X60.115 Y22.554 I23.776 J7.725 N09 X78.908 Y36.78 I-3.911 J24.692 N10 X67.554 Y69.521 I-22.704 J10.466 N11 X45.294 Y69.74 I-11.35 J-22.275 N12 G00 Z2.54 N13 M09 N14 M05 N15 M02 (END OF PROGRAM) N16 M30 % |
| G43 is a tool length offset, not a work offset. If you don't want to use it, you'll need to remove that line of g-code.
| Need Help!- No Work offset | Jelle_b_k | G-Code Programing | 1 | 06-16-2011 01:22 PM |
| setting work offset(G54 etc) | dek | Machinist Feedback | 1 | 04-06-2010 09:17 PM |
| Need Help!- work offset | Claude Boudreau | BobCad-Cam | 3 | 11-22-2009 05:41 PM |
| Newbie- Mach3 Z-axis disable when not in use | Erant | General CNC (Mill and Lathe) Control Software (NC) | 3 | 05-18-2008 06:52 AM |
| Running one work offset. | ltmquik | Haas Mills | 20 | 09-07-2007 01:02 PM |
