| error message from Mach3 after ver23 upgrade -------------------------------------------------------------------------------- After upgrading from bobcad ver21 to 23, I am receiving error message from Mach3. A window named Mach3 Scripts. reads, Error on line: 2-Unspecified failiure. When I click ok The second window named M3.m1s-Mach3 VB script E...reads, Do spin CW () set rpm... I was able to pinpoint the problem to the lines of code regarding spindle control.(by deleting them) Is there a setting in Mach 3 that makes it ignore the spindle command? I only got a manual router. When using profiling with multiple pass, I receive the error and need to reset on every pass . |
Check the Disable spindle relay checkbox under Relay control /ports and pins/config/mach3 |
| You shouldn't be getting this error, whether the spindle is enabled or not. In the folder \Mach3\macros\yourprofile, openM3.m1s in Notepad and see what the contents are. It should just be: DoSpinCW() Make sure there's nothing else in it. What version of Mach3 are you using?
this is all I got in that folder DoSpinCW() There was 4 square after (in notepad) that did not copy though Version R2.0.065 |
| post processor for mach 3? | njitnjau | EdgeCam | 12 | 11-23-2010 07:10 PM |
| Need Help!- Mach 3 Post Processor goes where???? | USMCCNC | G-Code Programing | 1 | 06-15-2010 12:17 PM |
| Post Processor for Mach 3???? | basskitcase | Rhinocam | 2 | 02-16-2010 04:28 PM |
| Mach 2 Mach 3 Post Processor | IntarisiaQ4 | Australia, New Zealand Club house | 0 | 10-17-2009 05:50 PM |
| Problem- re post processor v21 mach 3 | woffler | BobCad-Cam | 2 | 06-05-2008 09:49 PM |
