Page 1 of 2 12 LastLast
Results 1 to 12 of 23
Thread: Alibre CAD/CAM and MACH3
    Mar 2007
    I have a Small CNC mill running Mach 3. I just went though and calibrated the drives. Using Alibre CAD/CAM to make the tool paths.
    When I set my material in the Vise and move the cutter to the Corner which I set the MOPs to, I'll hit start cycle and viola the mill speeds off to never never land. This is a small part and not very complex.
    I've added the CAM code from Alibre. Hoping to find out why my Set Zero isn't a Set Zero.
    Smitty
    Mar 2003
    Shelby Twp, MI....USA
    When I set my material in the Vise and move the cutter to the Corner which I set the MOPs to, I'll hit start cycle............
    Are you zeroing the X and Y axis before hitting Cycle Start?
    Mar 2007
    Yes, Sir. In the Offsets tab of Mach3. I click the X, Y and Z offsets and than go to the main screen to start the cycle.
    Mar 2003
    Can I see your g-code, or at least the first 50 lines or so.
    Mar 2007
    Here it is. I am just doing two small holes, 2" apart, than clearing an area followed by a profile of the part.
    Thanks,
    Smitty
    G00 G49 G40.1 G17 G80 G50 G90
    G20
    (Hole Pocketing)
    M6 T1
    M03 S4500
    G00 Z0.0625
    X0.7761 Y2.2639
    G01 Z0.0250 F1.0
    Y2.2602 Z0.0238 F15.0
    X0.7770 Y2.2556 Z0.0223
    X0.7788 Y2.2512 Z0.0208
    X0.7813 Y2.2472 Z0.0193
    X0.7846 Y2.2437 Z0.0178
    X0.7885 Y2.2410 Z0.0163
    X0.7928 Y2.2390 Z0.0148
    X0.7974 Y2.2379 Z0.0132
    X0.8022 Y2.2376 Z0.0117
    X0.8069 Y2.2383 Z0.0102
    X0.8114 Y2.2399 Z0.0087
    X0.8155 Y2.2423 Z0.0072
    X0.8191 Y2.2454 Z0.0057
    X0.8220 Y2.2491 Z0.0042
    X0.8242 Y2.2533 Z0.0026
    X0.8255 Y2.2579 Z0.0011
    X0.8260 Y2.2626 Z-0.0004
    X0.8255 Y2.2674 Z-0.0019
    X0.8242 Y2.2719 Z-0.0034
    X0.8220 Y2.2761 Z-0.0049
    X0.8191 Y2.2799 Z-0.0064
    X0.8155 Y2.2830 Z-0.0079
    X0.8114 Y2.2854 Z-0.0095
    X0.8069 Y2.2869 Z-0.0110
    X0.8022 Y2.2876 Z-0.0125
    X0.7974 Y2.2874 Z-0.0140
    X0.7928 Y2.2862 Z-0.0155
    X0.7885 Y2.2843 Z-0.0170
    X0.7846 Y2.2815 Z-0.0185
    X0.7813 Y2.2781 Z-0.0200
    X0.7788 Y2.2741 Z-0.0216
    X0.7770 Y2.2697 Z-0.0231
    X0.7761 Y2.2650 Z-0.0246
    Y2.2602 Z-0.0261
    Mar 2003
    I'm assuming it's moving a lot farther than this?
    X0.7761 Y2.2639
    Before you click Cycle Start, do the X and Y DRO's both show 0.000?
    Mar 2007
    Artsoft Videos
    I'm currently watching the Mach 3 Videos again to see if I missed something.
    Smitty
    Mar 2007
    Quote Originally Posted by ger21 View Post
    X0.7761 Y2.2639
    Yes, Sir. I always zero the from the Home position before starting. I than go to a corner of the part and in the Offset page, click the X,Y and Z. For some reason after doing this, it's now wants to run off past the working area of my machine. FYI - Harbor Frieght, X-2
    Smitty
    Mar 2003
    I don't know what you're doing here?
    You can zero the X and Y from the Program Run page. You don't need to go to the Offset page.
    Mar 2007
    It's also odd, that the DRO reads correctly accordig to Calibrating the steps from the setting menu. I used a dial indicator to make sure 1" was 1".
    Mar 2003
    What are you're native units set to?
    Mar 2007
    Inches. I also zero the numbers in the Diagnostics Screen on the upper Left Hand side.
  • Page 1 of 2 12 LastLast
    1. Newbie- Anyone use V23 with Alibre?
      By sansbury in forum BobCad-Cam
      Last Post: 11-29-2010, 07:43 PM
    2. Need Help!- DXF to 2D Alibre
      By kawazuki in forum Alibre Design
      Last Post: 09-12-2009, 07:37 PM
    3. Alibre to DXF?
      By tikka308 in forum Alibre Design
      Last Post: 10-16-2007, 11:58 PM
    4. Alibre CAM coming in Alibre Expert 10
      By MichaelHenry in forum Alibre Design
      Last Post: 06-16-2007, 02:57 PM
    5. Alibre/ Alibre xpress
      By moyesboy in forum Alibre Design
      Last Post: 01-25-2006, 03:41 PM
