Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill
Old 07-07-2011, 03:29 PM
upnorth is on a distinguished road
Metric and Standard on the same machine
I'm wondering is it feasible?
I'm building a mach 3 based controller for a machine that has metric leadscrews. Can the machine use either metric or imperial models? I do not want to build a metric and an imperial based machine. I will mostly work with metric dimensions but will occasionally need to work in Imperial. I don't mind doing conversions on a simple model but it would not be practical to convert a complicated model manually from one system to another. I'm hoping that it can be done via software.
Beginner question for sure.
Thanks for any replies.
Tom
Old 07-07-2011, 04:44 PM
ger21's Avatar
Yes, you can use any screws you want. A 5mm pitch metric screw is the same as an imperial screw with 5.08 turns per inch.
The recommended method of running both metric and imperial parts, is to set up two profiles, one metric, and one imperial. That eliminates any chance of errors.
Although if you use G20 or G21 in all your g-code, the parts should be cut correctly. But the two profiles are easier, as you won't have to deal with conversions, and units switching.
How to change Fanuc 10tf from metric to standard? blakemachine Fanuc 8 02-27-2011 10:54 PM
Motor Couplings - Metric to Standard Jgeist Want To Buy...Need help! 2 04-19-2010 01:12 AM
Changing blueprints between metric and standard.... Redfinger General Metalwork Discussion 11 09-29-2009 10:10 AM
Problem- Threading Standard/Metric Bill308 General Metalwork Discussion 6 02-06-2009 05:22 PM
Standard tapping and Metric Programming. Dull Tool General Metalwork Discussion 3 02-01-2007 04:09 PM
